Super Stock Springs - Let's see em'?
002-003 ss springs
Here's my 67 dart with 02 and 03 SS springs with loweing blocks.
Tire's are 13.5 x 28 hoosier qt pro's.
Pretty good stance consitering SS springs.
Shot of lowering blocks
Car looks cool but I have a question...
It is my understanding that using lowering blocks with SS springs defeats the purpose of SS springs.... True? False? Maybe?
just sat it on the tires this morning
002/003 3000 lb springs with 235/60's with a 15x7 ralley
ill post more pics after i back it out
You can buy the adjustable front spring hangers to lower the car without blocks. 002/003 on my 64
Bob
Bob
Ditto That! 275-50-17's on 17x8;s with 4.5" bs, everything clears fine on an a-body width dana. I installed the adjustable brackets, and they lowered the rear to ~28.25" from ground. Look at the comparison photo below of the tired 36 year old 340 springs to the new SS ones.
Sitting high with -02 and -03's, 3200lb springs, the ride is not bad though:
'64 Barracuda with 002 003 SS Springs with 245/60-14s on 14x6 rallys. 1st gen Barracudas sit so low to start with.
I have 275/60/15 on my cuda in which they are 28" in diameter. I have a little over a 1/2" right there in the picture. The axle could go back towards the rear of the car would help out a lot.
I was thinking of somehow moving the rear end back 1" in order to center the wheel up in the fender well. I pretty much got it figured out but the only concern I have is yoke coming out of the transmission will move out of the transmission 1" without lengthening the drive shaft. I could have it lengthen but I'm not sure if it would really hurt anything.
Anybody got any opinions?
