Super-Cuda
MOPAR .. Move Over, Plymouth Approaching Rapidly!
spare / doughnut is T125/30R16
Pm me your e-mail or phone number and I will send you pics of it in the well.
PM sent . Thanks very much!!
You must have mis-typed that. There is no such thing as a "T125/30R16" tire. Besides, if there were it would only be 22" diameter... your rocker panels would be scraping the road!spare / doughnut is T125/30R16
you are right.....T125 / 80 R 16
good catch
that is what I get for having my cat read off the numbers....he mixes up his 3s and 8s all the time.
No problem guys! thanks for the post 69_340_GTS, and thanks HemiDenny for taking the time to check this out for me. Looks great and will work perfect for my application. BTW your Silver Duster looks unreal!! Love the red interior!!
glad to do it.....and that is "porno red" interior.
actually, there are three, this one (last of the three) starts once it came out of paint
it is kind of a long one......
A-Bodies...Big Motors / New Hemi Duster - FINAL ASSEMBLY
Thanks.....the detail is just part of the disease.
The aluminum Keisler bellhousing accepts both trans and back when I started my Duster build, I wasn't sure which (4 or 5 speed) way I was going. I decided 4-speed, bought one from Jamie / Passon Perf....then when I decided on the GV od and it came with its own aluminum tail shaft /adapter, I took the trans back to Jamie and he swapped it over to the aluminum case he started producing and added the GV tail. I kept and use the iron case for mock up. Jamies 5-speed was only on the drawing board back then (2005).
In April, I have a customer bringing his Scamp, Gen II Hemi, and other goodies to my shop for a HDK install. We will be using Jamie's 855 5-speed as well as all his conversion pieces.
No big mods for the Griffin Exact fit radiator other than a small notch on each side at the top of the radiator support to get the radiator to sit tight against it.....I needed the extra 1/4" forward for fan blade clearance.
Just got back from vacation and saw your videos. Sounds great, you'll be driving in no time. Somebody told me the temporary spare from a Crown Vic was a good fit in the trunk, and I think the rim is aluminum.
I run a high pressure (not high volume) pump. I also run 20W50 oil. Cold it almost pegs the stock gauge. Warm as I recall it runs around the middle or a little lower, and a little higher at cruise rpm. If you are using thinner oil and you have around 1/4 at idle and it increases closer to 1/2 at higher rpm I would say you are fine.
Mine came with the clock in the dash, and I replaced it with a performance indicator (vacuum gauge). I wonder if you ordered the rallye dash (150 speedo) with either the performance indicator or the tach and you ordered a clock, if they put one in the dash and the other on the console?
Your 'Cuda is coming along Fantastic.
Here are the pics of the installed Retro Audio system. This unit fit fantastic and was very easy to set up. Keeps the stock appearance while offering the latest audio options.
View attachment 1715159130 View attachment 1715159131 View attachment 1715159132 View attachment 1715159133 View attachment 1715159134
The USB charger in your console- I've been planning on doing this. Can you tell me the model number and/or where you got it?
Thanks.
