AJ... Now you tell me!
I just gave away a brand new Jacobs dial back device.... Lol
Oh say it isn't so!
That's probably my favorite tool..
It has so many uses. Together with a knock sensor,you can use it to determine a power curve in maybe a half an hour. Then, after you get that squared away, and with T-Port synced, you can begin the Vcan tune. Then for the rest of the summer you can use it to determine the maximum cruise timing she wants, and try to figure out how to get it. Finally, you can use it to tame the pressure pulses at idle so you can parade it.
Then, since by now you know what you are doing and are getting pretty good at it, you can charge money to fix all your buddys' machines.
Then,see; now you are really getting it, so one day you get to thinking:"do I really need to run 91 gas and pay the huge premium on it?"
Well, plug in that DB,and the KS,put in the fast-burn 87gas, and have at it. Maybe, just maybe you find out that; with a little tweak here and a little tweak there, before the day is done, you have her safely sipping that skunk-pee everybody is so afraid of.
Oh well.............................
