valiant1966
First the specs. I have a 66 Valiant that was /6 but now has a 318 with automatic trans. The engine has a very mild cam and a performer intake with eddy 4 barrel that runs a little on the rich side. Timing is 16 initial and 35 total. I have about 1500 miles on the engine and it has done this since day one.
I use a 195 thermostat that was tested in a pan water with a meat thermometer. I have tried 2 gages. One electric, one mechanical and both give the same reading. The lower hose has a spring in it so it doesn't collapse. I use a 50/50 mix of water and antifreeze.
I use a clutch fan and the radiator was used with my /6 with air conditioning. It was new and is rated for a /6 with air. Also has a shroud from the /6. I have a new Stant 16 lb. radiator cap that has been checked. I know some of the folks don't care for the lever type cap but it was checked and as long as they work properly I see nothing wrong with them.
Now, the problem. It seems that I can cruise all day long around town with no issues(190-195) but when I get out on the highway, the temps start climbing(up to 220-225 so far) and appears to want to continue to climb. It has never gotten any hotter because I always stop at that point not wanting any serious problems. Once it has got that hot, it doesn't really want to come back down when I get back to slower in town speeds but doesn't continue to climb.
I'm thinking the radiator is too small and not carrying enough coolant but I don't want to spend a bunch of money on a new one without having more knowledge about it. What do you all think? Sorry about the long post but you want details and now ya got them. Thanks in advance. Dennis
http://i968.photobucket.com/albums/ae170/obe1kanoby/Cooling2_zpse2b40b0e.jpg![](http://i968.photobucket.com/albums/ae170/obe1kanoby/Cooling2_zpse2b40b0e.jpg)
http://i968.photobucket.com/albums/ae170/obe1kanoby/Cooling_zpsc078630c.jpg![](http://i968.photobucket.com/albums/ae170/obe1kanoby/Cooling_zpsc078630c.jpg)
http://http://i968.photobucket.com/albums/ae170/obe1kanoby/Cooling2_zpse2b40b0e.jpg![](http://http://i968.photobucket.com/albums/ae170/obe1kanoby/Cooling2_zpse2b40b0e.jpg)
