Blind Squirrel
Did I miss it? I don't see anywhere in this story a question or a statement about oil pressure. Was there a gauge? Was there pressure? Was it steady or fluctuating? Just curious.
was it a stock shielded round pickup, they are, as has been said O K for the shield to touch the pan, cuz the screen/inlet is about 3/16" above. running a high volume pump? cuz I question if a stock pickup has a large enough area inlet for a high volume pump. performance aftermarket pickups like moroso and canton have larger area and no shield, they need to be 3/16" to 1/4" off the pan
It was a stock pickup.
The oil pressure gauge consistently showed great pressure throughout the driving time before the knock showed up and ruined the party. It gave me no indication there was a problem brewing.
Question? Not a statement. Possible cam bearings clocked in wrong? Shows good oil pressure but starves the bearings of oil?
It was eating more than the cam bearings... look at all of the bearings in the 3rd photo provided by the OP in his original post, and, in particular, the rod bearing pair in front of the 2nd piston from the right. Almost all of the bearings are showing signs of oil starvation or something that was badly effecting the bearing surfaces.
I have to wonder if the oil gallery plugs have been left out of the front of the block.
That I do not know. I believe the shop which rebuilt it originally just didn't have the Mopar engine knowledge base they thought they had. Typically they are rebuilding Chevrolet/GM/Ford engines, and my guess is that they just missed some of the differences involved in rebuilding the 340.When the motor was assembled/cleaned/ whatever during the rebuilding phase were any components Glass Beaded?
JW
very nice father and son photo. he'll be driving that dart very shortly.Well, after hearing a brand new (and alarming) knock coming from the 340, it was pulled Monday and discovered to have the camshaft bearings coming apart. Without going into the whole story, I had a garage rebuild it for me several years ago and it appears that their skills were lacking.
We're going with a new stroker kit to really strengthen it and get more ponies out of it.
I'll keep you posted as it progresses. Wish me luck. View attachment 1714967763 View attachment 1714967764 View attachment 1714967765 View attachment 1714967766
THAT sucks!Latest rebuild resulted in the same damage to the camshaft bearings after being run for awhile, so the block and heads are back at the machine shop. The current suspicion is that the Edelbrock Performance heads may be to blame in some fashion. No end in sight at this point....
Ditto.I do not see heads causing any of the problems
