The 70 Duster......
A lot (and I do mean A LOT) has happened around here since the last update. :evil4: The final downsizing from Fort Worth is now behind us! When we moved from Fort Worth, back to our hometown last year, we could not decide on where to build or buy a home. We leased a home in the area we thought would be close to where we wanted to build or buy. Well we decided to downsize even more than we thought! We bought a house built in 1964 that had been remodeled. So we have spent the last month sorting out a few things and upgrading a few other things. Since that is mostly complete we made a vehicle change and traded the VW Passat TDI (highway car) in on a Ram 1500! NOW are an all MOPAR garage again!! More on that later.
The Barracuda is progressing nicely.......Still needs to be sanded and buffed! :-D This is all I can show...:sad4:
Still never have figured out why I can only post one pic from my phone in each reply?
I can't post more than 1 either. iphone6 using Forum Runner. If I try to post a second pic the app goes black and I need to restart it id love to know the solution....
The car looks great BTW
Ordered from Classic Industries....
MD2068 - 72-79 Mopar Door Bumper (x4)
ME2236 - 70-74 E Body Molded Hood Insulation
MD342 - 72-76 Mopar Hood Insulation Clip Set
Vans Auto....
72-74 Barracuda Headlight Bezels NEW
72-74 Barracuda Grille Fastener Kit NEW
I thought you were just making this a daily driver?
Looks like a total resto to me.
Yep! The original plan was to make a driver. That lasted until I decided I needed to replace the dash. Since we were going to paint the engine compartment and remove the dash. It just snowballed. It was not my original plan but it seems to have worked out.
Ordered from Classic Industries......
ME1994200 - 70-74 E-Body Pillar Post Moulding (WHITE)
MM1443 - 71-74 Barracuda Rear Valance Bracket
MD2451 - 70-74 B/E-Body Lower Battery Cable Bracket
MN1780 - 71-74 B/E-Body Engine Wiring Strap KIT
ME5063 - 72-74 Barracuda Tail Lamp Rings (set of 4)
ME175920 - 72-74 E-Body Condenser OE
ME1016 - 70-74 Barracuda Manual Antenna
Vans Auto.....
Mopar Bucket Seat Mounting Nuts (qty of 8 )
Mopar 72-74 E-Body Day/Night Rear View Mirror
Mopar B/E Body Battery Tray Hold Down KIT
Purchased on Ebay from bs27h160...........
NOS Mopar 1972-74 Plymouth Cuda Lower Grille (Mopar Part# 3672933)
Hoover Auto Parts.....
70-74 Barracuda White Arm Rest Pads (Made in the USA)
Summit Racing....
P2998326 - Mopar Performance 26" Fan Shroud
Family portrait (dads car was MIA since he was not able to make it) from the Mopar Family Gathering today.
Purchased from Oreilly's Auto Parts....
PRE347 - u-joint
MTC2747 - Fan Clutch
MRY57059 - AC Compressor
MRY30-3206 - Receiver Drier
Autozone..........
CR109 - Ignition Control Module
Local car stereo shop
KFC-6965R - Kenwood 3-way 6x9 speakers
Purchased from Moparts member biggE...
small speaker grilles and braces for E body 3 speaker dash
From Wards Classic Car Radio Repair...
73 E-body AM radio (refurbished)
FL5719 - 19" OEM Style Fan Blade
ME1451 - 1970-74 Barracuda/Cuda, 1971-74 Challenger Dash Speaker Grill
ME1494 - 1970-74 Mopar E-Body Glove Box Liner
70351 - 1973-76 Mopar A / B / E-Body With Saginaw Pump Power Steering pressure Hose
MD2180 - January 1972 Date Coded Power Steering Return Hose Set
MD2182 - 1968-74 Mopar A / B / E-Body Power Steering Return Hose Clamps
MN1472 - 1970-74 Barracuda 4 Piece Stainless Steel Door And Quarter Top Edge Moldings
MN1474 - 1971-74 Plymouth Barracuda 22 Piece Door Top Edge Molding Hardware Set
MN1488 - 1970-74 Plymouth Barracuda Wheel Opening Molding Set
MD2322 - 1970-74 Mopar "La" Small Block Pcv Valve
ME5044 - 1972-74 Mopar E-Body Front License Plate Bracket
MN1868 - 1970-71 Mopar B/E-Body Automatic Brake Pedal Pad
MM1046B - 1970-74 Mopar B / E-Body Front Inner Fender Plates
MN2229 - 1970-74 Mopar E-Body Small Block Throttle Cable
MD600329 - 1970-74 E-Body / 1971-74 B-Body With AC Blower Motor Vent Tube
2444442 1966-74 Mopar Starter Relay (Except 1966-69 Model W/Mt)
From Autozone.........
4300 - Ignition Wire Set (black)
VR733 - Voltage Regulator
C819G - Ignition Coil Duralast Gold
DL7516 - Alternator
Oreilly Auto Parts....
S330 - Oil Pressure Switch (Sending Unit)
Thanks! It is amazing how close but yet how different the two colors are. The new Sublime has metallic in it. In the garage they look pretty close. Out in the sun, not so much. The new Challenger makes the Duster look yellow in some lights.
Ordered from Tube Technologies Inc......
E25MNM-TD - 2.5" H-pipe system from factory manifolds, without mufflers, for cars without cutout tip valance, with turn downs
Fleabay....
steering coupler repair kit - Either manual, or power, this kit contains the eight pieces needed to tighten up your classic Mopar steering issues. A,B,C,E or Ram pick ups
Dash is back in place! :blob:
Hopefully near the end of the parts list!!!! :cheers:
Inline Tube......
BSH7021 - 72-74 Cuda W/inner E Emergency Parking Brake Cable Set OEM Steel
Vans Auto Parts......
72-74 E Body Buckets Seat Hinge Cover set WHITE (2 pair)
I think this is last of the parts needed for the car!
Sourced locally.......
Optima red top battery
12256 - Magnaflow mufflers
Almost nice enough weather to drive. Pulled it out of the garage to let it warm up a little. C'mon spring time!!!!
Well it has been a really long time since I have posted on here. A year ago today my mom, very unexpectedly, passed away. So a LOT has changed around here. I actually made the decision to sell off all the old cars and I followed through with that to the point that I no longer own any projects or even finished cars. I currently own just three vehicles (our two daily driver pickups and the 2015 Challenger), and that is it. It is the first time since probably the late 80's-early 90's (high school) that I have only owned 3 cars. Not sure what the future holds but it was time to move on.......no regrets.
