geardaddy
Active Member
dana 30 was mentioned on 2 pages so I thought that I would try to save someone some headaches. sorry I lost my head.. by the way, the dana 35 uses 8 ring gear bolts, the 8.25 uses 10 ring gear bolts..Yeah Dana 35
I still question the two housing theory. I know there are two carriers, seems like 2.56 is the split on them.Crap...This thread is information overload.
I do not know any more now than I did when I clicked on this.
Yes that is the split. Look at the pinion the higher ones are off centered more.I still question the two housing theory. I know there are two carriers, seems like 2.56 is the split on them.
someone else in this thread reported getting lucky and getting it to work with a spacer and some bearing changes I think, but that's pretty rad.In 2008 I bought a '74 Duster with a 2.45 geared 8 1/4" axle. Later I pulled a 3.55 SG diff from a Dakota 4wd. Even with limited skills, I switched the diff and gears into the axle and it all fit and worked. THIS tells me that the axle housings and center section of those two were at least compatible. It also leads me to understand that it is the differential itself that is different.
Ok, so I scanned this and did not see this. Correct me if I'm wrong. This thread is talking about the carriers basically, not the entire housing? Reason I ask is I recently saw a 98 Cherokee 8.25 rear end with 3.55s for sale not too far away. Drum brakes. Seeing if it would just require perch relocation or if it had to be shortened too.
post#3 shows the differenceI have had two different carriers that were definitely different. when set on end side by side you could see with the naked eye one was taller than the other where the ring gear bolts on. There was talk of two different housings? I never bought into that.
$300 American is about $410 Canadian plus I have an offer for the 8.75 of $350 $750 so if I can locate a 8.25 with BBP for $100 I am $650 ahead. Money left over for new wheelsWhy on earth would you not buy BBP axles for you 8 3/4? Dr Diff sells them for 300.00.
Yes that is true but like I said if I got an 8.25 then I could sell my 8.75 to someone that is after it already for $350. So $350 for the 8.75 plus I'd be saving $300 American which is in actuality (at today's rates) around. $410. $410 plus the $350 I'd get for the 8.75 is actually $760 minus $100 for the 8.25 that already has a BBP. Basically if I keep the 8.75 I need to spend $410 for the Dr. Diff axles. Just to be at the same point as spending $100 on an 8.25 that already has the BBP. So right there I am up $310 then I sell my not needed anymore 8.75 for $350 which puts me at $610.Must be Canadian math. If you sell the 8 3/4 for 350.00 and you can find a 8 1/4 for 100.00 which will more than likely be a 2.45 open , you saved 250.00 for less of a rear end.? But hey it’s your car.
Haha. Yeah also I'm only building about 350 hp so I figure the 8.25 is good for that plus it's not as heavy and not as much go needed to drive the 8.25 axle. But I am definitely sticking with the 8.75 if the savings aren't enoughLike I said use guys do dat fuzzy math, eh.
350hp? Budget minded? Personally I'd have the 8.75 axles redrilled for LBP for now. Take it easy save up your money and swap them out later. JMOHaha. Yeah also I'm only building about 350 hp so I figure the 8.25 is good for that plus it's not as heavy and not as much go needed to drive the 8.25 axle. But I am definitely sticking with the 8.75 if the savings aren't enough
Alright thanks for this info. I am very ignorant about the 8.25. figured this thread would help me out. I did not know about the crappy gear ratios. I think the guy that's been asking about my 8.75 is going to be upset. Oh well. That's life. Thanks. I have the front disks out of a 76 dart so I was trying to find the least expensive way to go to BBP out back.Most A body 8 1/4" axles have crappy highway gears and no SG.
