george joseph reid
Yeah the carrier seems nice and tight. Putting it together till I can find an 8 3/4 to fit. Saw someone on here that used a B-body with relocated perches.
The thread is about the Mopar 8.25 rear end. This was used in Jeeps and other Mopar vehicles but never Fords. It does not share any components with an Explorer or Ranger, nor does it share components with the Dana 30 or Dana 35, so you will want to limit your search to the vehicles with the Chrysler 8.25 exclusively.
Ford uses the term Traction Loc for its limited slip differentials, it has no relevance to the 8.25 Chrysler rear end. There are most likely many videos or informational articles on the web regarding setting up a rear end, checking pinion depth, backlash etc. a simple Google search should get you all the instructional video and articles you can use. Special tools like a pinion depth gauge and dial indicator will sure make the job easier but aren't a deal breaker, you could get it done with a simple caliper if you are creative. Good luck in your search and build!
I've been reading this thread religiously for some weeks to make sure I'm not gonna mess up so thanks for letting me know I should be good. I appreciate the amount of time you spent putting this whole thread together!Another thing you can steal from the jeeps are the rear disk brakes.
Yup It is in the disk thread somewhere. You also want a adjustable proportional valve also the stock one will not work properly.I've been reading this thread religiously for some weeks to make sure I'm not gonna mess up so thanks for letting me know I should be good. I appreciate the amount of time you spent putting this whole thread together!
I just need to make a new parking break cable if I use those right ?
I don't have any more chuncks but this should help.Yes, if you have some pics or other info that will shed light on a Dana 35/8.25 interchange I would like to see that. I have been in the drivetrain repair business for nearly 40 years but I learn something new every day.
thought that I would point this out before someone buys a bunch of parts that they can not use, but A Dana 30 is much smaller than the 8.25...@memike and myself decided to start a thread all about 8 1/4 rears and common problems. Lets start with carriers and housings. The housings are two different distinct easy to identify The first is the most common with the pinion centered for 2.57 ratio and down the other is the off center pinion carrier for 2.56 gears and up. see how the pinion is off centered.
Here is the 2.56 and up carrier.View attachment 1714937812 View attachment 1714937812 View attachment 1714937813
Yeah Dana 35I believe the focus is on a Dana 35 and 8.25 parts swap? Not Dana 30?
