skrews
If you could pick the best aspects of any of the OEM castings and roll them in to one head, how/what/why would you choose ?
they should have made the W2 a production head. Then all the expense of a W2 would not be! no special mani, exh or rocker arm....they would have been stock production parts! :cheers:
Valves- 2.02 and 1.6 diameter of the X but with the 5/16 stem diameter of the Magnum
340/360 intake port ie X,J,587,596
308 casting exhaust port
T/A offset intake pushrod hole
302 casting chamber sized for 4" bore
Magnum 10 bolt valve covers (less leaks)
Yea, they tried to on the original Little Red Express trucks. darn. They may not have been as plentiful as other production heads though. Maybe like the Max Medge heads were?
Then, not one single other small block, from any other American automaker wouldda stood a chance in hell against a factory hot W2 headed 340. Many big blocks wouldda been shut down too.
http://smallblockhemi.com/ Itchy trigger finger, if I had a winning scratch off ticket. Although, I would have liked to see a better individual rocker shaft stand setup.
I'm sure that would've been OK to deal with ;)
...other side of that is that it would've forced the other folks to step up and market something better than what they offered at the time.
Anyone here known to be running this?
the little red engine I know of was a police spec E58 360 engine, nothing too special really, just good flow and decent HP, the E58 package was made for a few years in different appications
