Much has been mentioned about what works best for the 273/235 HP Commando Engine
Casting #2658920 Cylinder Heads.
Going with a 273 Block, and bored .040 to a finished bore of 3.665"
I'm asking for input from the Technical Thread.
The car will used for the Drag Strip, as we are entering with a group of match racers who
will be entering this 'Special Pony Car Class' for cars that had a weight break of 12.50 to 13.49,
based upon manufacturers advertised horsepower and shipping weight.
We're going with 10.5 - 1 Pistons, a Lunati blueprinted stock camshaft, and 4.89 Gears in a 4-Speed car.
Cars must use the stock-type camshaft, and maximum 4.89 rear-end gears. Obviously headers, and 9" wide-slicks
are permitted.
Stock intakes must be used, but Carburetors up to 600 CFM are permitted.
The stock cylinder heads can have matched ports (intake and exhaust), no deeper than 1/4", and no runner porting.
But, any size valve can be used, and the combustion chamber can be polished
Experts,,,,,,,,,,What do you suggest.
are permitted.
