abdywgn
dismantler
At this point, how difficult would it be to install the engine from the underside with the headers/k-frame assembly?
I don't know but that was my original plan! I built a dolly that enabled me to take the engine and trans out as a unit so for all intents and purposes it should work to put it back in the same way (see post #303). The column, steering linkage and T bars would have to come out. That stuff is pretty easy to put back in so maybe?At this point, how difficult would it be to install the engine from the underside with the headers/k-frame assembly?
I’ve done the installation of the engine in the K frame and lowered the car on top of it before by myself on the floor of the driveway. I did have to take the intake off since I couldn’t lift the car as high as it needed to be, which is of no concern to you if I remember your in house equipment.I don't know but that was my original plan! I built a dolly that enabled me to take the engine and trans out as a unit so for all intents and purposes it should work to put it back in the same way (see post #303). The column, steering linkage and T bars would have to come out. That stuff is pretty easy to put back in so maybe?
Yeah, it's a big cam for the street. Funny too because the original one they suggested was even bigger. I went back and looked at the lobe list and found similar ones with a little less duration at .050". When I called back I think I spoke with the owner. He said the ones I came up with were good choices and he would have suggested similar if not the same ones.I don’t care what others say about that cam, it’s big. IMO, once your in the 260@050 area, it’s a sizable camshaft. At 11-1 W/that cam, you can drive the street and use pump gas.
What header brand/style is being used again?
Right it's Shark tooth, not "Sharkstooth". I'm an idiot.Ether grill looks good IMO. I like the shark tooth grill a little more probably since it was a bit more uncommon. I think it looks great.
Maybe, IDK since I’m not a numbers guy, but the Twister might have been a place to get a shark tooth grill as an option?
Again, IDK.
No big deal. Idiot is about the last word I’d describe you with.Right it's Shark tooth, not "Sharkstooth". I'm an idiot.
I don’t remember any more. I was always about power and speed. God bless the restored, all hail the hot rodder!Anyway, I believe you're correct in that you could get the Shark tooth grille with the Twister package. My guess is the inclusion of the vinyl top is probably what excluded the sporty grille option because the combination of the two looks a little odd. Twisters were painted roofs AFAIK.
They were quite popular! It just sucks underneath after many years outside.The decor/package designers probably figured the secretaries and grade school teachers who were driving 318 2bbl Dusters didn't care about a racy look. The vinyl top gives it an illusion of class. "Let's tart up our basic transportation model with a top hat so people think they're getting some amount of luxury." Right.
As I remember it, many people did that stick on side stripe bumper deal. I thought for the longest time it was a stock item.My car had stick-on side molding too to prevent parking lot door dings. It stands to reason people who bought 340 Dusters probably didn't spend much time at the supermarket so preventing shopping cart dents was likely less critical to them. 318 2bbl Dusters probably spent more time in shopping center parking lots than anywhere else.
No doubt. My latest garbage, the ‘71 rust bucket, is a factory two tone. If you ever get to that time where the final top goes the way of the wind, keep the trim for it as the two tone cars kept the trim on dividing the paint.And yes, I did think about all that before I bought the grille... I do wish my car didn't have a vinyl top. If I ever decide to paint the exterior it's gone.
Thanks. I broke my hip skateboarding in November of 2018. The bone was repaired 'back to stock' and healed but a few years later I was in a lot of discomfort because the bone tissue was actually dying from lack of blood flow. Ultimately the joint had to be replaced. It's now ceramic and cobalt. I feel it every now and again but no more pain and it's probably stronger than the boneI enjoyed reading and catching up on your project. Lots of projects start here also, but to my wife's dismay, they don't get done. Hope the hip is up to snuff.
