This car is not a commuter, it is just a toy.
I put spacers in the right side like these:
The reason? I couldn't get the camber to where I wanted with the caster that I could get. I'm being reminded of how inter-related that caster and camber can be.
In short, I started down the road of doing my own alignment because I suspected that the alignment shop that I used may have lied about the numbers on my car. I was told it aligned to over 5 degrees of caster and when I checked with this gauge, I had 3 degrees on one side and 3 1/4 on the other. I messed with the alignment cams and was able to get the 5 degrees of caster on both sides but the right side camber was only 1/8 degree and I wanted more. In theory, I could have just used those ball joint spacers to gain the negative camber.
The QA 1 arms at full caster came in around 8 1/2 degrees.
I'm just curious about what negative effects I might have with a caster number that high.
Hard to steer at slow speeds? I have a manual transmission so I could rev the engine a bit to speed up the pump.
It looks like I could get 7 1/2 to 8 degrees of caster and 1.0 degree of negative camber with this car.
I could just align it, lock down the cam bolts and drive it to see.
