replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,346
- Reaction score
- 8,871
And this the metallic grinding compound/oil mixture right out of the crank journal....
Engine has the typical "old school" trw forged pistons, at .030 oversize with extremely heavy scuffing, and were in the cylinder at .005 piston to wall, the cylinders are all fairly even size wise, but 3 or 4 have almost. 002 taper, which is definitely no good.
The pistons definitely dont look new for a engine with a supposed 80 miles on it. The scuffing is probably debris, but the mess at the top was probably poor honing of a rusted boreDo the pistons look new?
Can you tell if the piston and cylinder wall scuffing is from recent debris in oil are there before startup?
Getting the rod and piston assemblies out, we find factory 340 floating rods, that DO appear to have been re-sized with new bolts. However they didn't bother with the wrist pin bushings, which are worn beyond tolerance. the crankshaft journals are worn severely undersize, and out of round, giving us a whopping .008 rod bearing clearance. Knock knock, whos there? Sad situation indeed!
The crank wont wear like that, in that short of time, the bearings take the brunt of it. My speculation it was worn out when it was installedCan you tell if they undersize and then polished before startup? Or did the recent debris in oil wear them out of round?
Very possible, but cant say with 100% certaintyThis look like a hone only job on a previous .030 over block?
Stock 340 floating rodsDoes this motor have Eagle H-beam, stock, or aftermarket I-beam, rods in it?
If I ask you politely to stop hijacking this thread about THIS particular 340, would you oblige? Thank you sirWhen rebuilding a engine, it doesn't always need to be bored. I don't understand why people think that it's not a rebuild if it's not bored. I knew a guy that rebuilt his engine with 50k on it and he didn't have it bored, why? Because the bores were in excellent condition and still had the cross hatch so why waste the money having it bored.
It has std King rod bearings, plain aluminum. It has std clevite 77 main bearings, forgot to check the dateBackside of the bearings? Who's the manufacture? Date code on them?
Need a plug in the top hole
