Confusedcuda
I just sent the member I bought this from a link to this thread
Next step is to thoroughly clean the block, and take some more measurements. The bottom end is absolutely hammered, it may need a line hone, and I'm pretty concerned with lifter bore wear, but we will wait and seeIf the block passes inspection, what’s realistically in the works in the way of machine work to bring it back to usable other than the usual rebore and home and paralleling (or at least straightening) the decks? If there’s a case of failure that hammers a bottom end enough to make it necessary to line bore or hone an engine, I would think that this one is probably there.
No real signs of cap walk, but the cap registers are a little looser than I like.Any signs of cap walk? I’m guessing the main cap bolts have had to take a beating, too. A grenade in the making, the only difference is it’s turning a key instead of pulling a pin…
Just curious, is there actually a fix for that?No real signs of cap walk, but the cap registers are a little looser than I like.
From my experience, it seems more like it's the cap rather than the block. The blunt nose chisel works, but most of the time I find I can stick a different cap on the block and its tight. That would require caps that fit close to correct on the main bore, and then a line hone job howeverJust curious, is there actually a fix for that?
Anyway, continuing with the autopsy, it definitely doesn't get better! By somehow, much to my absolute amazement, the camshaft, while worn out, did NOT lose a lobe....the lifters however look worse than any lifter I have ever removed.
Lesson here is the proper break-in the first 80 miles, or you can get into trouble real quick !!
That's extremely generous of you, we will have to let the owner of the engine @Confusedcuda make those decisions.@replicaracer43 I have a few brand new small block flat tappet cams squirreled away. I will donate one to the cause if one would work for this build. They are all small duration street grinds.
Not usable in this block, and skirts heavily scuffed. Maybe they could be cleaned and the skirts coated, but there are way better options these daysAre the TRW pistons salvageable enough to resale or did they get reduced to scrap aluminum?
Because it's more descriptive than "crap" But it's just it had a stone touched on the intake side, seats too wide, exhaust side the seat was not cut concentric, and they we leaking.Why would you describe the valve job this way?
Concord NCreplicaracer43 for those of us who don't know where is your shop? You are doing a stand up job as well as helping out, I would be happy to send you work.
Its really up to the owner to disclose that if he chooses. There IS a possibility that the seller was screwed over by the machine shop that did the work, and perhaps truly believed the engine to be as described. I really dont know.So we - or some of us - know who the seller is? Think it's time to identify him for the rest of us, especially since he's still selling.
He can respond if he likes, or not, but he needs to quit hiding.
Exactly what this site is about, and why it's absolutely THE BEST!A lot of good folks willing to help and donate parts, This is the way it should be. I love it.
