dartindanno
I shipped the crank today. Good luck with the build!
As per normal these days, waiting on parts, but did get the hardened seats installed in the X heads, and valve job roughed in...@replicaracer43 Any updates?
Those are some huge weight differences. That can't do anything but help.
Rotating mass and inertiaThats a big weight savings. The little engine that could rev!
I will say this though. There've been MILLIONS of those old heavy *** TRW pistons used through the years and they ran fine.
It sure didn't matter in A12 cars that were raced the hell out of either.Exactly. I am building a 440 with the old TRW six pack pistons and rods.
Others talk about how heavy they are, and they are technically correct about the weight.
But does it really matter in an RV engine that won't spin north of 4500 rpm?
As long as you have a good set of rod bolts I say no.
Bottom line, for a 340 street engine if I had a set of the TRW forged heavy pistons would I use them? Sure. If I had to buy new pistons though the lighter ones (provided a rebalance is in the budget) are a no brainer.
122.1g is a lot of carbon build up...LOLWeighing out the new piston and rod combo is pretty interesting, but not at all suprising. This engine came with a set of ancient TRW flat tops, they weigh 732.5 grams, compared to 610.4 grams for the KB flat tops
