I want to know what Oregon does to the guts of these lifters.
As far as I know, nothing. I believe they just remachine the face. We will disassemble them when we get them back and update.I want to know what Oregon does to the guts of these lifters.
Interesting, what do you do to update internals?As far as I know, nothing. I believe they just remachine the face. We will disassemble them when we get them back and update.
The good news with lifters is, they spend their whole life slam fulla oil so their hydraulic failure rate is probably pretty low.As far as I know, nothing. I believe they just remachine the face. We will disassemble them when we get them back and update.
The reason we used the older lifters, is they were nearly new in the early 80s, ran only a short time, so by using them, we know we have better metallurgy than the china ones available currently. We will disassemble and inspect/clean internally, but I think our chances are pretty good!I'm hearing that new lifters aren't cutting the mustard. Is this the only option these days?
Wonder what is causing failures, assuming correct methods are used for installation, along with coating all surfaces with a break-in lube typically supplied with cam & lifters? Metallurgy?
Good stuff here folks
If I lived close to him, I'd have no problem taking stuff to his shop. I can tell, he'd be particular to almost a fault... lolreplicaracer43 is a stand up machinist. Nice shop. Since I only lived an hour away, I went there in 2020/2021 with the date coded 340X heads from the 68 GTS 340" I bought to fix up. Very nice shop. Extremely clean. Dude cares about his work. Whoever this motor is for, they are in good hands.
That's a thing of beauty. Got to love a freshly machined short block.Got the lifters back from Oregon cam grinders, they look excellent, disassembled each lifter and cleaned internally, and in case yall thought we were sleeping, started the shortblock assembly.
Question, My old purple cam was put in the box my new cam came in.Got the lifters back from Oregon cam grinders, they look excellent, disassembled each lifter and cleaned internally, and in case yall thought we were sleeping, started the shortblock assembly.
I read on the box , warranty void if use of reground lifters.
Your thoughts on why?
Thanks
I wont be the least bit surprised if this cam fails, there is simply NO guarantee on cams and lifters. Keeping our fingers crossed and taking every possible precaution
It's a new melling grind, pretty mild, and thanks for the offer!What size cam???
I have a few older ones sitting around and can donate one if needed...
Exactly how ALL machine work should be done.If I lived close to him, I'd have no problem taking stuff to his shop. I can tell, he'd be particular to almost a fault... lol
Looks great! Do I see a positive deck clearance?Got the lifters back from Oregon cam grinders, they look excellent, disassembled each lifter and cleaned internally, and in case yall thought we were sleeping, started the shortblock assembly.
Yeah, I'm extremely apprehensive about the Ford 400 I am now swapping into Gladys. I got the Crower Camsaver lifters from about 5 or so years ago, as I collected parts ahead of the actual assembly. I hope they are good. Single springs, .515 lift old school Crane Fireball. I hope it turns out.I wont be the least bit surprised if this cam fails, there is simply NO guarantee on cams and lifters. Keeping our fingers crossed and taking every possible precaution
Yes sir!Looks great! Do I see a positive deck clearance?
I thought so! How much are they stickin out?Yes sir!
If I remember correctly, its .017 out of the hole. One side was way different, and twisted so i had to cut more than I would have liked. Also had to machine the piston tops to keep the compression in check after all the square deckingI thought so! How much are they stickin out?
I believe I calculated it to be about 9.4 after all said and done.How much squeeze do you think it'll have?
Can't remember if you've mentioned this before, but is that with stock, uncut heads?I believe I calculated it to be about 9.4 after all said and done.
