There are some quick 71 Demons and Dusters that run NHRA stock classes. 10:60's with no problem! They seem to be the fastest of the A bodies
I don't know of any notch back 68 or 69 'Cudas being campaigned. There are several fastbacks though, 340 and 383 powered, and a few 69 440's.
Pa karp
Pa Karp,
Back in November 1967,
Jimmy Boyd, who was a 'minor factory backed' Mopar Driver tested a 'new' 1968 Barracuda Notchback,
340 4-Speed, that was equipped with 3.91 Gears.
Jimmy was also a Charter Member of the famous and just 'newly started' Motion Performance
Supercar Club, based out of Baldwin, Long Island, New York.
I'm sure the Barracuda was Dyno'd and 'dialed in', but otherwise it was 'All Stock'.
The new Barracuda was test run at Cecil County Dragway, where it also won in Pure Stock Class.
Jimmy had several test runs in Time Trials, and put down a best of 13.89 @ 101.17 MPH
in winning a Class Trophy in B/PS {9.50 to 10.59 Wt/Hp}
So you admit it was not as it rolled off the showroom floor. Got it! LOL
Pointing out the HUGE fallacy with your premise.
From the factory, as a regular joe could buy them. None of the A cars ran better than 14.20's in purely stock form. No distributor recurving, jetting/rod changes, lowering, drilled shocks/shock packages, lightening or any of the other tricks that were done by the cars as tested.
As pointed out earlier, when was the test run, middle of the dog days of summer or on a cool crisp fall evening/day? Nobody really gave much thought to DA in 1968-1971. Test at OCIR then at Las vegas and see how that fast car runs .4 off.
Post bomb away... more written east coast diarrhea to follow. Bandwidth killer!!!
Pa Karp,
Jimmy Boyd {Greenville, North Carolina} who was a 'minor factory backed' Mopar Driver tested
a 'new' 1968 Barracuda Notchback, 340 4-Speed, that was equipped with 3.91 Gears.
The new Barracuda was test run at Spartanburg Raceway, where it also won in Pure Stock Class.
with the converters the stock cars use from the factory, the 4 speed has a huge advantage. 46 pounds more is nothing when you can launch the car at whatever rpm you want to
Did they run B/PS in 1971?
Did a 71 Duster/Demon with 3.91's ever run in that class?
I started in F/PS and moved to E. Engine factored by NHRA
My best was a 14:50 flat. BONE stock. I will go along with the 13:89 and 13:90 after seeing who worked on the cars and knowing the Pure Stock rules. This just proves the potential of the cars. The E/PS record at TV was a 14:35 back then. I was just a dumb kid, but could have got there with a little help.
The Sox and martin ad sold cars, no doubt. I attended one of their seminars in Brookings, SD. Huge crowd!
Curt Rees
And you claim on other threads that no 340 duster car ever hit 13's stock box from the factory....... And proceeded to claim that those that claimed low 14's were exaggerating? Now this???? One day I'm crazy for saying what you have posted, now you are saying it?? Ok, I get it now....The 'Top 7' recorded times from Back-in-the-Day.
Stock A-Body cars with > 3.91 Gears and E70 x 14" Tires
#1 ..... 1968 Barracuda 340-S Notchback ~ 4-Speed............. 13.89 @ 101.17 MPH
.......... Driver > Jimmy Boyd
......... Track > Spartanburg Raceway {South Carolina}
......... Date > November 1967
#2 ..... 1968 Barracuda 340-S 'Fastback' ~ 4-Speed ............ 13.93 @ 101.39 MPH
#3 ..... 1968 Dart GTS 340 ~ 4-Speed .................................. 13.94 @ 101.10 MPH
#4 ..... 1971 Duster 340 ~ 4-Speed ...................................... 13.94 @ 101.25 MPH
#5 .... 1969 Barracuda 340-S 'Notchback' ~ 4-Speed ........... 13.97 @ 100.40 MPH
#6 .... 1970 Duster 340 ~ 4-Speed ....................................... 13.98 @ 100.33 MPH
.......... Driver > Ronnie Sox
......... Track > Orange County International Raceway {California}
......... Date > March 1970
#7 .... 1971 Demon 340 ~ 4-Speed ...................................... 14.04 @ 100.01 MPH
not so fast the trans in 71 was tweaked slightly had a higher stall, and higher shift points, different VBbingo
Hey look at my post of the 50 fastest no 340, this was buy the trusted magazines back then car and driver , hot rod, road and track and a few others. That list has been around for a while and generally accepted as fairly correct, your 68 cuda 340 runs as fast as the 440 68 cuda LOL.
