flathead31coupe
What I meant?Is the primary extensions?Do they set on top of the quad?Rings or do they go in the middle of the quadrings when you put it together. The accelerator pump rod and choke pull off rod doesn't look the same... I am also missing the little spring on the choke assemblyNo, the X-rings drop into the wells in the bowl to seal the primary extensions on the top housing. What rods appear incorrect? I might have spares.
