gerty
Has anyone used a Lokar kickdown cable on a T/Q? Pics of the hookup method to the carb would be very helpful. Lokar's instructions are not much help.
Thanks, Bob
Thanks, Bob
Yes it have and there product, pictures and directions are not for use with a TQ. Or OE AVS & AFB carbs.
The Edelbrocks can use the kick down cable because they use the throttle adapter. This provides a location for the cable.
PROBLEM SOLVED!
The adapter lever, I took and used its profile view to make a flat plate and drilled 3 holes in it. 1 hole for the throttle stud, 1 hole for the little hole on the carbs arm and 1 at the bottom for the lokar cable. I bolted said flat plate on the TQ's arm at the stud and a nut and bolt you need to source out from a hardware store.
Somewhere in this forum in my vast amount of posts, I have a picture of this on a OE AVS.
When I get home, I'll see what I can whip up for you.
Thank you and my pleasure Bob.
I knew I had those pictures. 10 years ago! LOL!
And now, to get the brain working, what design can you come up with. I was working on another one of those plates and though I would make the shape the MoPar omega "M" to employ.
What your basically doing is making a flat version of the adapter part Edelbrock or Holley sells.Does anyone have the measurements where the 3rd hole would go? I just want to make sure I put it in the right place when I make this.
The measurement just about 2-1/2 inches (center to center) exactly, downwards and 3/4 of an inch rearwards of the top connection hole on stock MoPar Carter carbs.
Other Carter carbs used on other makes will vary there attachment points.
Nice work!
This is precisely what I just ran into, and determined I may have to make my own bracket from the Edelbrock adapter also. I'm surprised an appropriate adapter isn't 'out there' to buy.
64 Dodge Dart GT
'68 318 engine
TF 904 trans
I have the Lokar TC-1000HT throttle cable , the KD-2904 kickdown cable, and the SRK-4000 Throttle Cable Bracket
From what I can tell, I may also have to make or modify the Throttle Cable Bracket because it is NOT LONG ENOUGH to reach the extra width of the ThermoQuad Carb. I think it would be easy to bolt on a short extension, just won't look as tidy. I highlighted it from your own photo. Is there a longer bracket to buy or did you just make one that was a little longer than the SRK-4000?
