slimjim
So I've delayed asking for help for awhile now but, with one day left, I need help. About a month ago my bcuda just decided it wouldn't start. So I went through some tests and sure enough, no spark. I popped my dizzy cap off and found both centri adv springs had popped off and were stuck to the magnetic pickup. So I took it out and replaced the springs. Still nothing. I have the summit ignition box which has an LED light as an indicator and while I'm cranking there's no flash however, once I stop it flashes once... Not sure if that means anything. I've got power going to the box and all my connections are right. Any ideas? The car is hard wired for only the fuel pump, alternator, ignition box, and starter.
