i think you have a mismatch of parts , big cam how far down the hole are those pistons ? you should be able to idle under 900 for sure . holley is easy to rebuild so start with that . compression is way low . and the lights dimming With Crackedbacks relay is weird .
think you have a bunch of little problems that have added up Good luck getting the car running right
