Trying to figure out a hard start situation. Want to cover all my bases. Does this install look correct? Give me your opinions good or bad. Thanks for looking.
I say no...
the two drilled dots need to be facing each other..
the cam gear dot should be at six o clock, the crank gear dot should be at 12 o clock... you currently have them both at 12 o clock
Oh snap good eye I never saw the top dot!!I say no...
I think you found the problem
Do what?? #1 tdc should be crank &12 cam@6? Right?No, that's actually incorrect. Cam gear at 12 and crank gear at 12 is correct and TDC on number 1. The way you describe times it on number 6. I could see the dot on the cam gear at 12, but I cannot see the dot on the crank gear.
Teach me because I am officially lost.No, 12 and 12 is correct. For the second time.
I understand that the crank will make 1 full revolution before the cam gear putting the cam at 12! But when your starting out and put the dissy on 1 it should be 6 and 12
Ohhhhh I see what you are saying now..No. #1 TDC is crank at 12 and cam at 12. You see crank at 12 and cam at 6 in every single manual because it's easier to time that way, but that's timed on number 6, not number 1. 12 and 12 is correct.
6 and 12, 12 and 12..the crank could care less where its at as to him its the same. Either will get you set up, now you just bump it until you feel compression on #1, then run it to the 0 damper mark. Bingo compression TDC now line up spark plug tower to rotor. If you dont like it, just turn crank 1 time, hey the dot is at 6! If the rotor wont line up, pull pump drive out and turn it so it does, remember it will clock a little on its way down. You may have to turn the crank a little for the drive hex to interface with the oil pump.
Yes the procedure most people use is line them up 12 crank and 6 cam then rotate it around so the cam is at 12 and crank is at 12. THAT is number 1 TDC. I just use a steel ruler and line them up right the first time at 12 and 12.
Yes. Let me try to enhance the image. I'll get back to ya......Are our old asses supposed to see some timing marks in that picture?
Just quick and easy. Does this look to be a tooth off?Ned a lot more onfo
