Well here's what the FSM says.
(7) Place both camshaft sprocket and crankshaft
sprocket on the bench with timing marks on exact
imaginary center line through both camshaft and
crankshaft bores.
(8) Place timing chain around both sprockets.
(9) Turn crankshaft and camshaft to line up with
keyway location in crankshaft sprocket and in camshaft
sprocket.
(10) Lift sprockets and chain (keep sprockets
tight against the chain in position as described).
(11)
Slide both sprockets evenly over their respective
shafts and use a straight edge to check alignment
of timing marks (Fig. 26).
(12) Install the fuel pump eccentric, cup washer,
and camshaft bolt. Tighten bolt to 35 foot-pounds.
(13) Check camshaft for .002 to .006 inch end play
with a new thrust plate and up to .010 inch end play
with a used thrust plate. If not within these limits
install a new thrust plate.
(14) If within limits, slide the crankshaft oil slinger
over shaft and up against sprocket (flange away
from sprocket).
Then later in the FSM:
Distributor Timing
Before installing the distributor and oil pump drive
shaft, time engine as follows:
(1)
Rotate crankshaft until No. 1 cylinder is at top
dead center on the firing stroke.
(2) When in this position, the timing mark on vibration
damper should be under ("0") on the timing
indicator.
(3) Coat shaft and drive gear with engine oil. Install
the shaft so that after gear spirals into place, it
will index with the oil pump shaft, so slot in top of
drive gear will point to the first intake manifold bolt
on left side of engine as shown in (Fig. 42).
