Called Charlie myself, should have it back today.Well, do you have the new pan?
Tincup - what did you wind up doing with the front floor? Saw pics of it missing - but nothing else.
Gonna start kicking off a build on a '64 Cuda - your build certainly has provided a wealth of info so far. Keep it up!
Tincup - what's a ballpark on the 5.7 from the factory?
In my opinion, if you plan on driving it, a Gen III is the only way to go. I purchased my "New" 2005 5.7 LX (car motor) for 3K in the crate. Of course there are a few additional items you need like alternator, different oil pan, exhaust, but you will need that no matter what you build. The motor will still utilize the MDS along with an overdrive automatic, this car will have 350hp and should get 25mpg on the highway all day long, Let's see you do that with a 440.
Sounds to me like someone is compensating for other "Short" comings....I cant see me doing that cause I can't see my speedometer and fuel gauge to tell what kind of mpg I get from my stroked 440 BB...........I'm always blinded by white, thick, foul smelling smoke that seems to be coming from the rear of my car near the point where the tires used to be making contact with the road......It won't stop even when I shift up into 3rd......These #$*$&@!* big blocks are nothing but trouble I tell ya.
If I went 3G I wouldn't have to deal with 700HP and almost = torque. It's NOT WORTH IT.....I only get 12 MPG on top of that. I feel this way every time I get in and it fires it up on the first try. It's a crappy feeling no doubt.
Your right to stick with new technology and sacrifice brute HP and torque for economy and better traction.:snakeman:
It's the green thing to do.:toothy10:
Mop
Its all in fun UNo
I didn't know MP made one, I'll have to look into that. Thanks...I had the same problem with the charles pan. I used the Mopar performance pan on my demon.
I think the pan is made by Milidon for Mopar. They look the same . It was cheaper to by the mopat one with an employee discount then the mildon thru summit.
Its P5153643 . It also cam with the dip stick and oil pickup tube. Here is a pic of k fame . it was midified to use a tock 45 deg oil filter adaptor.
