dibbons
Enjoy the video:
Yeah and it's better to do it regardless. Although, I've replaced many a rod bolt right here at home and not resized the rods. I did it like that in the Ford 400 in Gladys and she's been fine for about three years now. It wasn't a money decision, at the time there was nobody around that would do it. Machine shops around here at that time were non existent.The only way to know for sure if a particular rod(or set of rods) will need resizing after new bolts are installed is to swap out the bolts, torque to spec, and check the sizing.
They either need it or they don’t.
Sure. Why not? Won't hurt a thing. He had plastic jaws installed on it.Is that acceptable/ normal operating procedure to put the micrometer in a vice like that?
Like with cylinder heads in particular, with the price of aftermarket chromoly rods being what they are compared to cost of new bolts and reconditioning the stock 5140 steel pieces (and having seen the outright repeated abuse they can take in a stroker!), it makes me second guess wanting to go that route when you can upgrade for not much more...
That's the flat out best way. Make it a requirement for a build or don't do the build. You cannot warranty someone's stupidity.I sized every rod that came through the shop. It wasn’t an option.
Yeah, no doubt the greater factor involved.it’s not the clamping load that distorts the rod. It’s the criminal press fit of the bolts.
I'd call B.S. on that too... Only with the addition of ring dowells around the bolts or cap screws or (in the case of Gene Fulton, at least) register grooves machined in the cap to rod interfaces.The extra press fit makes the rod/cap interface stronger.
This is what I found out when I finally decided to totally go through my 340, again. Some too short so junk.Remember to, there's more than just the size and roundness of the big end ID. There's the LOCATION. If the big end ID isn't in the right place, it will affect the rod's center to center length.
It's unfortunate, because a lot of shops don't even check length. They just get the hole round.This is what I found out when I finally decided to totally go through my 340, again. Some too short so junk.
Which sucks because I originally paid to have them resized and balanced with the rotating assembly. Basically I got a Friday afternoon job.
I tend to agree. Only reason I didn't on my 400 was because I measured before and after and there was very, very negligible difference.I was told by a guy who owned one of the best machine shops in Little Rock about 35 years ago that any time you buy new CR bolts, you need to resize. I am NOT saying anything against anyone, I am just repeating what he told me. BTW, he did an AMAZING job doing the machine work on my block and crank and balancing my 340.
I'm willing to bet that a lot worse than the precision wer'e talking about came out of the factory back in the day...I tend to agree. Only reason I didn't on my 400 was because I measured before and after and there was very, very negligible difference.
In my opinion, the factory 'precision' is a lot better than people give credit for.....
And when I hear, comments like my deck was out 0.015"......yeah right.
Two simple examples bear this out:
- Mopar main brg caps are indented to the block on V8s. A snug fit, might need a tap to insert. Half a thou too tight, doesn't fit; half a thous too loose, drops into place.
- cyl head dowels. Half a thou out, & head needs 'help' to fit over dowels.
Using the 'common sense' derivative, why would other machining operations that are less obvious than the above be less accurate?
I'm absolutely certain. Just look at all the other tolerances. Deck height and such.I'm willing to bet that a lot worse than the precision wer'e talking about came out of the factory back in the day...
lol factory “precision” is far from it. It’s just good enough to get by.
But keep in mind we are talking about mass produced parts, mass assembled engines. I wonder how much time was actually spent on checking tolerances during casting, machining and assembly. I have read stories about how engines were checked and when oversized pistons or bearings were installed a special symbol was stamped. So I know there was some level of checking, but how much? As fast as the engines were being manufactured, could everything on every engine be checked?I'm absolutely certain. Just look at all the other tolerances. Deck height and such.
Oh yeah. I've had a few engines over the years marked with the Maltese Cross. That means non standard size "somewhere".But keep in mind we are talking about mass produced parts, mass assembled engines. I wonder how much time was actually spent on checking tolerances during casting, machining and assembly. I have read stories about how engines were checked and when oversized pistons or bearings were installed a special symbol was stamped. So I know there was some level of checking, but how much? As fast as the engines were being manufactured, could everything on every engine be checked?
Glad somebody brought that up. Resizing is only a good idea IF you have at least a competent machinist to do the work.This is what I found out when I finally decided to totally go through my 340, again. Some too short so junk.
