dartfreak75
Restore it, Dont part it!
Here is what I get when run the numbers. Im not sure how much that gasket compressed but I know what it was when it was new so im gonna go with .050 is 150 psi low for this scr?
I completely misunderstood this comment yesterday I thought you ment cranking pressure like on the starter lol. Thats why I asked how do I do that. Now that I reread it today I know what you ment lolYeah, that's probably a little much. Have you measured cranking pressure yet?
Extreme to you or the engine? There are 2 ways to time it. One is where you (or others) want it and the other is where the engine wants it. As of right now, you haven’t really driven it enough to know what the engine wants. Make yourself or others happy and there is a chance your engine will not be.Im just trying different stuff. I have read different ways to improve performance with timing and tuning and im just trying it out. Im new to this part of it. Im just trying to learn. I agree it does sound extreme I thought it was alot of timing too that what made me want to ask questions. Im gonna have to limit my dissy either way. I originally set it around 14 and it runs good there.
Yea I haven't driven it enough to really know what it needs I'm just going off what the vacuum gauge says and the affects to the idle.Extreme to you or the engine? There are 2 ways to time it. One is where you (or others) want it and the other is where the engine wants it. As of right now, you haven’t really driven it enough to know what the engine wants. Make yourself or others happy and there is a chance your engine will not be.
1. Late timing will build heat much faster.I understand there is more than one way Rusty.
What I'm saying is that you don't have to pump so much timing into a car just to stick your chest out and say look at me, I have 20 initial. Maybe for a quarter mile blast. Backing it down a couple clicks will give you an all around much better running motor, that will also last much longer. No hiccups with the starter, no pinging, no knocking, no burnt pistons, and an overall cooler running engine. I also can run 87 in my cars, Have you seen gas prices in California ?
I'm sure Kevin will get it sorted out.
Thanks for the nice comments.
factory 68 383 magnum is 155 psi at 3000 feetEngine was warmed up. Around 150 It was not at WOT. After reading some of these posts I didn't realize 140-150 psi was considered low compression lol my old 318 barely broke 90s haha
Felpro 8553pt 4.180 bore. It doesn't have a listed thickness i measured it at .056 and figured it would compress .006. It may compressed more or less.
2. If your vacuum increases then your combustion is more efficient.
3. Late timing sends unburnt fuel out of the tailpipe.
Now that's the last think this is about. Some combos won't have a decent vacuum signal or have good idle quality (good as they can given the camshaft) until timing is up that high......so trust me, it ain't about stickin titties out....although I like seein the right ones stickin out.
Which is why I mentioned "mild" small blocks. Do you read anything I write ?
I still stand by my statements.
You talk a good game Rusty, but I will compare cars with you anytime, anyplace. Lol
Say hello to my tail lights buddy.
I don't understand why you guys insist on running so much timming on your mild motors. There is absolutely no reason to run 20degs initial on a mild small block, especially when your total is way off the scale.. Most mild SB's run just fine around 12-34. If you are at a track, ok try some different settings. But for an every day driver/street car, there is no reason to ring the car out on the jagged edge over timming it. 12-14/34-36 will be more than sufficient.
Well spoken. You basically stated everything I stated in my videos.Just what is "mild"? A comp XE268H likes anywhere from 16-20 initial timing in almost every car I've ever tuned. And to me that is a VERY mild camshaft. Stock 318, 340's and 360's like 12-14. Start putting larger cams in them and that number goes up.
Initial timing doesn't kill anything... total timing is where you get hurt. And getting the complete system (initial, total, curve) correct takes a little work.
Engines will tell you what they want for initial timing. Give them what they want within the mechanical limits of the total system and be done with it. Dialing back on timing is a crutch and was done by the factory for one purpose, to meet emissions guidelines. That's why later cars were timed at such crappy initial settings. 68-69 cars barely had sufficient initial timing by the book.
I agree but too much can hurt power at idle.Initial timing doesn't kill anything
Exactly. Initial brought down 5 degrees or more compared to the same engines without CAP, and the AFR leaned out to 14.2. Idle rpms increased to help compensate for the loss of power.Dialing back on timing is a crutch and was done by the factory for one purpose, to meet emissions guidelines. That's why later cars were timed at such crappy initial settings. 68-69 cars barely had sufficient initial timing by the book.
the one that causes the maximum amount of gas pressure to be delivered to the crank at the exact right time. IIRC this is ~28*ATDC. But I have read other numbers.
As rpm, loads ,temperatures, and elevations, change, the BEGINNING of the gas expansion strategy has to be adjusted to achieve that.
That's the crux of it isn't it.
Whether the piston is 28* or 25* into the power stroke probably depends on the crank arm and rod and stroke ratios. ... Thats one of those little details that makes each engine a little different. But it really doesn't matter, the concept is the same.
For those that may be not following why we're talking about pressure in the cylinder. It's all about maximizing leverage on the crank.
