Here's a great video. It is what it is.
https://www.amazon.com/GREENWATER-Waterproof-Bootfoot-Cleated-Fishing/dp/B09YHD5SBF/?tag=fabo03-20On our race engines (Especially Small Block Mopars)
not only do we use a Deck Plate but we home the blocks
at the water temperature that we actually stage the race cars
at. Does it make a measurable difference? I do not know but we
sure do get our feet wet a lot and go thru a lot of Socks.
Haven't yall won a lot? Kinda answers that question, don't it? lolOn our race engines (Especially Small Block Mopars)
Yep! Love listening to the guy.That's still worth watching just to hear about "Fairy Dust and Unicorn Farts!"
Honing blocks at 'operating' temps makes SO much sense to me.On our race engines (Especially Small Block Mopars)
That’s it right there. IMO, while it won’t really add any meaningful power to the daily driver, the race engine will have a small benefit to it. It asked for my last engine to be bored and honed with a torque plate since it’s slated to be a race engine. It makes sense here.He said if you are building a race engine or rebuilding a certain block (like the FE Ford) you should hone with one.
Like he said, If you are freshening up your wife's Yukon LS it's probably not necessary. Pay the extra and have it done if you choose.
We have a bunch of chickens and I have noticed =Haven't yall won a lot? Kinda answers that question, don't it? lol
If you are building a sophisticated enough engine, then yes. Also if you are anal, yes!Would you check, set ring end gaps with the torque plates and water too?
How round the cylinder is makes a hell of a lot more an issueWould you check, set ring end gaps with the torque plates and water too?
I understand that. I was on a different forum years ago and they talked heavily about using water at temperature for boring and honing blocks and they found no real difference in horsepower or ring sealing or longevity, but I don't know this as fact nor do I have any experience with it. But it seems to me that it would have a differenceHow round the cylinder is makes a hell of a lot more an issue
with ring seal than a thou or two in the ring gap does at least
in our shop!
When I was buying some equipment ~20yrs ago, I discussed hot honing with them, & they said the NAPCAR guys were trying it but it wasn't getting the results they were expecting. I said that didn't make sense, & was curious why, so I stayed plugged in to it.....turned out they needed to pre-heat the honing oil, otherwise the cooler oil caused distortion, plus the type of stone was specific. Any insights of Your own You'd share? Much appreciated.How round the cylinder is makes a hell of a lot more an issue
in our shop!
If You've ever pulled the head off of an AMC 6 including an HO 4.0L, the crosshatch is gone adjacent to the 1/2" head bolts, like a 5/8"-3/4" swath. Like He said, some get it all the time because they're prone. This is when folks don't get why a BRM 'dingleberry' hone works better needs pointing out, the engine torque plate honed itself while running & stress relieving itself, if bore taper etc. is in spec. the BRM won't undo it.He said if you are building a race engine or rebuilding a certain block (like the FE Ford) you should hone with one. If honing at operating temp works for you then go for it. Like he said, If you are freshening up your wife's Yukon LS it's probably not necessary. Pay the extra and have it done if you choose.
That "clown" is me... And his entire video is a misconstruing of what was said. Massively misleading.It’s also in the wear of the piston and cylinder. How it looks at the refresh time.
This guy I have seen before and he knows what he is doing first off and second off, who ever that idiot who she is talking about is a first class *** clown that should t be allowed to have a computer, much less a 9/16th combo wrench.
Reminds me of a few *** clowns here.
