what do y'all think a 318poly converter will stall behind a healthy 440 in a 66 coronet convertible........Artie
thanks for the reply on this.that's what I was hopping for and yes it is an 11inch.thanks again.....Artie2000 to 2200 maybe? Thats about an 11 inch converter isnt it?Only reason I went that high is the power behind it.
Too late RRR debunked the myth with his guess and the godfatha enacted it and the results will go down in history....hard to believe huh?What year Poly? Early (up to 1966) the input shaft on the transmission had 19 splines, and the converters were a 12" NOT a 11". In 1967 they changed to a 24 spline input shaft, and my catalog still shows a 12" converter for the early 440 engine. You might also want to check on the diameter of the converters pilot, and make sure it's the same size as the bore in the crank.
According to my replacement converter catalog, it made NO difference what engine, except the hemi and the max wedge, was in front of a 727 up to 1966, converters were all the same, and were rated as a medium stall unit. I doubt that you'll get much more than 21-2200 rpm out of a factory 12" unit.
Yea he just kinda sits back and watches,lurking in the shadows,waiting for some fool to cross the line and WHAM!! right in the forehead with a pistolgrip...lmao..just funnin yaR.R.R, knows the basic from the old days. The cool part is,not swayed by hype and propoganda.
