1. scatpakman
    scatpakman FABO Gold Member FABO Gold Member
    275
    9
    Jul 7, 2008
    Osseo, MN
    Local Time:
    8:40 AM
    I'm looking for recommendations on trans coolers. Specs are 500ci LD stroker 560hp/590#. 727 Torqeflight. 4000 stall converter, 3:91s.
  2. Dusterdenovo
    Dusterdenovo Contentedly Old School
    1,029
    2084
    Dec 10, 2011
    British Columbia
    Local Time:
    6:40 AM
    Delighted with my B&M Supercooler.
  3. roccodart440
    roccodart440 Well-Known Member
    5,758
    4750
    Apr 19, 2010
    Local Time:
    9:40 AM
  4. jbc426
    jbc426 Well-Known Member
    2,002
    809
    May 30, 2007
    West Coast
    Local Time:
    6:40 AM
    Like these guys said. Use the plate type. I run running two of them instead of a single one for fitment reasons in my '68 Barracuda.
    Instead of a thermostat, I use a pair of small ball valves to bypass the coolers in the winter or when I'm just making short trips around town, so the radiator can put some heat in the fluid.
  5. scatpakman
    275
    9
    Jul 7, 2008
    Osseo, MN
    Local Time:
    8:40 AM
    You wouldn't happen to have a couple pictures of your set-up would you?
  6. jbc426
    2,002
    809
    May 30, 2007
    West Coast
    Local Time:
    6:40 AM
    I'm working on the car this weekend and will snap some. Do you need pics of the valve set-up or the placement of the two coolers? I'll post both.
    Regarding the lines, i used to slightly flare the ends of the cooler lines to allow the robber hose to hang onto the ends better, but I have since switched to a compression fitting style of end with a hose barb on it.
    Be sure to tighten and loosen the compression fitting end of it several times to allow it to seat onto the steel line. I suspect stainless steel lines would even require more of this process to get them to seal reliably.
  7. scatpakman
    275
    9
    Jul 7, 2008
    Osseo, MN
    Local Time:
    8:40 AM
    Thanks!
