redfastback
Don't ask me... my garage is empty
just to play it safe, check voltage at coil at idle. should be 7-9 volts. definitely check that all grounds are solid. where did you run the electric choke wire to?
What are the symptoms of a fuel pump going bad? im reaching here, My uncle said he'd help me out next weekend when i go down to pull my cousins engine. But, it would feel good to figure this out myself
