And the bell housing as far as I knowCan you switch the ball and trunnion to a slip joint? ps if you run the 340 go with the 10.5 clutch.
To check if it has 3.09 gears, put some tape on the input shaft and output flange and make a mark at 12:00 on each. Put it in first gear and rotate the input one revolution. The output should roll over a little over three times.
The other first gear ratios for an 833 are roughly 2.4x and 2.6x so it should be a no brainer for what you have.
Sorry but just the opposite of above ^^^.That's Alot of OverDrive!
Second gear in the OD trans is 1.67. Second gear in the non-OD 4-speed with the 3.09 gear is 1.92.I remember a discussion here about the 3.09 first gear, if the 2nd gear is near the same as anA833
Aluminum With OD, the rpm will drop significantly
Yes, if you use the slip joint main shaft and extension housing.Can you switch the ball and trunnion to a slip joint? ps if you run the 340 go with the 10.5 clutch.
No need. If your B&T front universal is in good shape it'll handle just about anything you can dishnoit. They used that set up in the 426 Max Wedge. 425hp factory rated.Can you switch the ball and trunnion to a slip joint? ps if you run the 340 go with the 10.5 clutch.
