I agreeNo .003" or less is just a coating meant to make the appearance look better...
Thermal barriers are much thicker to be of any use...
.003" for a thermal barrier does as much good as pissing in the ocean to raise the water level....
Terrific read. Thanks for finding it! My take-away from it is that the coatings didn't do much to increase hp's on the dyno, but most definitely reduce under-hood temps in a significant way. See below:Well guys... Seems that everyone's perspective has some merit in this discussion, according to this article in Hot Rod , where they tested the coatings for performance gains.
This is a good read!
A Look at High-Tech Engine Coatings and What They are Worth - Hot Rod Magazine
This shows a problem in the testing. Ambiant (air) temperature can not be read with a 'gun'. They can only read surface temperatures. Even there, on the more expensive ones can be set to compensate for the surface reflectivity.In any event, ambient temperatures with a heat gun in
I say so...
I think ur wrong on this one , may be why ur --- "crazy" kuda !! LOL
With a 440/505 , with raised port heads in a 68 barracuda engine compartment , I`d welcome 100* less compartment heat !!That’s a lot to read. I’ll stick ith my measure, TTI’s 100 degrees cooler underhood. Even if that is the only benefit. Heat is the enemy.
That doesn't mean the test is invalid. Just their summary interpretation of what they were measuring is incorrect. A surface near the header very well could have been 200* cooler.
It's unfortunate there's no specifics about the coating.
It could have been whatever it is these folks use. Xtreme Performance Heat Coatings
or one of these products of the same name. Xtreme Temperature Coating - High Temperature Paint - Header Paint - Stove Paint
Really no information about the products in either case.
Damn....I like that!!!!!Old saying " Quality is remembered long after the price is forgotten "....
It took TTI 7 weeks to get my headers out to me after ordering. I was pretty disappointed in that. On the plus side, they dropped in on my 440 70 GTX with only having to pull the motor mount bolts (I’m swapping out the heads to Trick Flow 240’s so the heads were off of the block). Bolted on the heads and the headers fit PERFECT!!!!! So far I’m happy. Hope to fire it up this weekend.It makes sense that any type of coating/barrier that keeps heat in the pipe, will lead to better performance. Theoretically, if the tube stays cooler, there will be more of a "draw" which will lead to more power. That said, it's only a 318 with a stock 340 cam and stock 318 heads, so I wouldn't expect the "thermal barrier" option from TTi to result in a noticeable difference in power. I was more interested in the lower underhood temp, and keeping a little more heat away from pumps/wires/reservoirs/etc under the hood.
It seems like everyone generally rates both Doug's and TTI very favorably, and very comparable to each other, with an ever-so-slight edge to the TTI's . I was prepared to shell out the $$ on the TTI's, but with the 20% off deal through Auto Zone, the ceramic Doug's really are only $560 right now, compared to $954 (incl shipping) for TTi. That's hard to pass-up on its own, but when you add-in the fact that TTI says there's a 4-6wk lead time for the 273/318 headers, I think I'm going to go with the Doug's.
