j.mcconnell
are the lower control arms and strut rods still pivoting at the same position? it looks like the adapter on the k-member end of the strut rod would push the pivot back and cause binding? any video of cycling the suspension without the coilover spring?
bonus idea: couldn't you build brackets off the k-member to put the lower control arm mounts in double shear and eliminate the strut rod
