Could you send some pix of your wheel and column..side shot too..?It’s not a big deal at all. I commented on your other thread already, I have 16:1 manual steering, 275/35/18 tires in the front, and +6.5* of caster. I use my Duster (Demon clone) as my daily driver. It’s not a problem. Not the easiest car to parallel park, but it’s not impossible either. Once you’re doing 10 mph or more it’s a piece of cake.
If you have the standard 24:1 manual steering and a less aggressive wheel and tire set up than I run it shouldn’t be a problem at all.
Thanks for the pix..! You've convinced me with those.. Really digging the crush can too.. Appreciate the help..!These work?
They're older pictures from before I installed the 6 speed manual and procar seats. The Tuff wheel is a reproduction sold by Dale's Cuda Shop. Mine is actually a "blemished" one from eBay, occasionally the "blem" ones pop up for a little cheaper. Not a perfect copy of the original, the wheel cushion is a harder rubber/plastic material than the original foam. On a daily I actually like the harder material better though, it holds up better.
Also, my crush can (adaptor) is not an original A or B-body length. I made mine custom out of a much taller E-body crush can. The A-body length is not reproduced, at the time they were more expensive then the E-body ones (I know right!?) so I cut an E-body one down and made it the length I wanted it. You can see that in the last picture, the crush can has a rib in it still. The E-body crush cans are ribbed like that (with a bunch more because of the added length), the original A/B body ones are smooth.
Thanks for the input..! I'm just gonna do it...can always go back to the monster wheel of necessary.I much prefer manual steering amd have used a tough wheel on a few cars. Not bad at all. But I also run smaller tires on the front.
These work?
Also, my crush can (adaptor) is not an original A or B-body length. I made mine custom out of a much taller E-body crush can. The A-body length was not reproduced at the time, and they were more expensive then the E-body ones (I know right!?) so I cut an E-body one down and made it the length I wanted it. You can see that in the last picture, the crush can has a rib in it still. The E-body crush cans are ribbed like that (with a bunch more because of the added length), the original A/B body ones are smooth.
Looks very cool..! So, what was the fabrication process to shorten the crush can to get to a body length..?These work?
That carbon dash is awesome!!
Thanks for the info... Looks greatly.!Thanks! It’s a custom overlay from Detroit Muscle Technology (DMT). I worked with the owner Jim to make a pattern for the lower overlay which they now offer. I don’t think he’s doing the lowers in carbon anymore, but I’m sure you could work something out with him if you really wanted one.
Probably about what you would expect, I used the ribs on the E-body can as a guide to keep my cuts straight and just cut a section out and then welded the can back together. I made reference marks so I didn’t rotate the steering wheel mounting studs compared to the splines on the other side. And I tacked it in place and went slow TIG welding it back together, checking that the ends remained parallel as I went.
It’s actually not A-body length either. I took measurements based on my seating position and put the wheel where I wanted it.
