Tunnel ram Tuesday!!!...
Tunnel ram in process of being way better than original Tuesday.
Welded the plenum to the runners, added about 300 feet of rod to the outside of the plenum and tapered down the runners, then I cut the carb flange off so I can port this easier.
Im thinking of flanging the top so I can make a twin 4500 carb top.
And yes, I agree the welding is butt ugly
upper right port is where in starting to get my size and taper figured out.
The heads that Wally Booth, Maskin & Kanter used were two heads cut apart sectioned and welded back together. They were crazy, but what they had to do back then to be competitive.
Tom
Thanks. I love the ingenuity of people
This picture has a before and after of port shape.
Epoxied the exterior of the runners after welding because I didn't get enough aluminum.
After sizing the runners I did some work in the plenum and welded the top back on, I have a little bit of work left to match the ports after I finish porting my tf240s a little bigger.
