604B1duster
- Joined
- Dec 30, 2007
- Messages
- 1,561
- Reaction score
- 821
This is still in the same spot waiting
Sure no problem! And for s**** and giggles can you send me the money to do it... You know the money for the 9-in risers two of them, the eight studs, the throttle cable that will need to be longer..J-par, just for ***** & giggles can you put about 9 more inches of spacer & repost your pics
Have you had the car out much this year ? Are you going to make it to the track to test the nitrous ?I just really wanted enough riser for the carburetors to be seen.. with just the tunnel ram all you can see is the air filters coming up.. with the 2-in riser plus the half inch nitrous plate the carburetor actually pokes up through the hood...
All most never and not likely..Have you had the car out much this year ? Are you going to make it to the track to test the nitrous ?
Your power wagon is going to be sweet, sorry I don't have the extra money to make sh&ts & giggles...lol, I just thought you may have the parts laying around somewhereAll most never and not likely..
I've only had my go kart out once this summer.. Between work and the power wagon project there's not enough time..
I have the aluminum, I started a job at a machine shop near my home, not much free time figure when my engine is finished & home I can mock my heads on a junkie 383 block & get started. I'm pretty sure it's going to be fall though, it's too dang hot around here in central WaSure no problem! And for s**** and giggles can you send me the money to do it... You know the money for the 9-in risers two of them, the eight studs, the throttle cable that will need to be longer..
The new gaskets, the new more extended fuel line.. the new hood with the bigger longer hole in it so it can be opened up and down without being lifted off every time taking two people...
How's welding together that homemade tunnel ram going for you that you were talking about at the beginning of the year here earlier in the thread?...
I am so happy with my tunnel ram I can't see why I wouldn't put 1 on the race car. I also need a Max Wedge port tunnel ram. Is a sheet metal one better or less expensive than an Indy?
This is why I put the 2-in risers underneath my carburetors just so they kind of popped up out of the hood a little more...
