Mad Dart
Nothing to see Here!
Custom Manton Pushrods. 3/8's Shafts .145 wall Hardended with 5/16 Hardened Ball Tips that Oil Thru.
You are more than welcome to come for sure but there is no date as of yet. I need to get the electronics ordered and going. This Dyno Session will last 3 days more than likely. There's alot going on. Tri Nozzle Meth Injection, Intercoolers & Pump, piping, Heat Exchanger & Fans, etc, etc. I am going to try and have all the wiring done as a Plug and Play to all the sensors with all the values set for everything in the Tuning Program before I schedule the appointment.
Thats the catch with posting on websites..
People will copy you.
How much were the pushrods? I want to get the same for my stroker.
I haven't measured. I have they same rockers as you used though. PM me a price if you think they will work with rhs heads. They are cup style.
Man, you have a lot going on with that. A guy at work was telling me there's someone in San Marcos building a TT small block stroker, too. I wonder if it's someone else from this forum, because they way he was describing it was very similar to yours.
1wild&crazyguy Thats the catch with posting on websites..
mind if I ask what brand TB that you're using?
I love this build..its making me so anxious haha!!
I bought a nissan Q45 TB, its more like 85(ish)mm...But it looks like the TPS is the same as the one you ended up using.
What kind of bolt pattern does it use-nissan also? Im having a bit of difficulty finding any intake elbow that will go from a holley carb to a nissan TB (go figure). So i think the cheapest route is to make one, as you were going to...
You could consider moving the Alternator down. Some people have them mounted down low, but I'm not sure exactly how they do it. That bracket for the driver side looks good!
Your setup has truly inspired me to do a tt setup on my 67 barracuda. i'll be using a 360 with a 727 trans. I've been throwing the idea around since i've obtained the vehicle and really didn't know exactly what i would be getting myself into considering this would be my first turbo build. Your thread has been so helpful with answering alot of my questions. Between reading this thread and talking to my engine builder i'm pretty confident in putting this setup together. I can't wait to see your beast up and running took me about 4 hours to read the entire thread today so now i'm excited to see those numbers.. Good Luck!
