needsaresto
- Joined
- Nov 13, 2004
- Messages
- 7,603
- Reaction score
- 266
Looks like the pass side wants to go straight thru the heater motor.Why not run it into the interior and heat the car too,lol!
Not everybody lives in the frozen tundra of Canada :toothy10::toothy10:Looks like the pass side wants to go straight thru the heater motor.Why not run it into the interior and heat the car too,lol!
No I bought these here: http://www.summitracing.com/parts/TRD-4695/
I will be making my own SOLID MOTOR MOUNTS though! I raised the engine about a 1/4". When doing this swap from a 6 to an 8 the motor mount on the passenger side is ALOT thicker than the Solid Motor mounts you can buy. Sooooooo the solution to that problem is to make my own!
That's funny!:-D
My 70 Dart gets warm enough inside with TTI Headers on it. I never use the blower motor.
Heater/Blower??? Plenty of hot air coming from the drivers seat area. :-D
Looks good Louis!
that lower column bearing, the one they don't make anymore, is gonna be toast.
check into an after market column, I know theres a couple that make nice billlet [or billet looking] columns for that car.
lookin good brougham!
by the way have a new lower column bearing/bushing, that im not using, came with my alterktion kit, yours if you need it, will only sit in my toolbox, we are using a stock car style column
Luke
Mr2.4:Man you are doing some awsome work! If I could make one suggestion though. I would ad a v-band just past the elbow on your down pipes so you will be able to remove them easily to change your sparkplugs.
Dodge29:awsome build, want front row seat when you go to change plugs, probably wont be much fun.....great looking work.....awsome...first class
Mad Dart: Anyway I got home today and the spark plugs will go in without any other modifications. I need to use an extension with a swivel on the end is all....
