famous bob
mopar misfit
Moper,
the reference to F1 engines is that they go totally against todays thinking of what the ideal bore/stroke-rod ratios should be. i just thought it was interesting! 750+hp and only 250-300ft-lbs of torque will lay waste to most cars on the 1/4mile lol.
cheers
dgc333,
then they couldn't have used a long enought rod with a shorter piston..otherwise it woulda been significant. you wouldn't happen to have a link would you? or specs on what they did?
cheers
dis agree , a 750 horsepower engine w/ 700 ft lbs of torque would kill it , in the same weight car, w/ traction.
