:-Dtks.i will crawl under it and lookup the numbers on the tranny.that particular car has been tampered with so much i call it the box(in honour of the brick from mopar action)i dont mind its a keeper(along with my duster of course)as found it had;67 valiant front clip with fiberglass fender(cracked)held on with robertson, screw 3 door from a different 67 valiant,68 taillights and back bumper,67signet trunk lid,67 seatbelts,68 dash assembly(in dash key hidden by mounting tach on top of it)67 signet 2 door buckets,71 floor shift steering column with 67 steering wheel!3 inside door panel are 67 1 is 71, engine is a early sixty slant six,starter is pre60(no gear reduction)cast iron bellhousing and the underhood wiring is duct taped togheter a real beaty!!
p.s. its registered as a 67 under the 71 serial number!!(i will take care of that soon)
p.p.s. as im returning it to a 71,all the other parts will be up for grabs.
