Don't forget that you can't turn the bolt to remove them, it has a flat side in the adjuster cams. When mine get that rusted i use a 2 FT. breaker bar on the nut (after penetrating oil of some kind). They either turn loose or snap the bolt.
If the bolt snaps i have always been able to drive it out with a bent punch and a big hammer.
