US Car Tool Early A Body Frame Rail Connectors
On the emergency brake cable, leave it hooked up when you test fit the sub frame. you will have to mark where it crosses the sub frame and drill a couple large holes. Then after it is welded in stick a pry bar in the hole and bend the pry bar in the direction that the cable runs to help the cable avoid the sharp edges.
I can take a pic if needed.
Or use rubber grommets
With the angle I do not think grommets will help, you could cut an oval hole to get clearance.
Here is it looks like:
I would have to crawl under mine and look. Is that the cable without the sheath on the left ? The grommets should keep the rattles quiet.
