Valiant progress
The headers did fit good, but slighhtly rub the pitmann and idler arm. I had to tweak the headers a bit. I was slightly unhappy with the ceramic coating of the Dougs, inbetween tubes they were not coated. They had assembled the header, then coated it. A couple of the primary tubes were touching, and they were compression bent at the joints rather than a mandrel bend (if that can even be done on headers?). For my stroker, I wished I would have went bigger than a 1 5/8 primary tube thogh.
I was gonna mention about the Doug,s 1 5/8 tubes with the Eddy heads.I too got the Dougs(from Summit 10% off $70)sent them back and got the Hedman Huslers 1 7/8 tubes for less restriction on the ported Eddy,s.I,m racing ,so not for looks.LOL
Hey Stroker, Does all that fit under your stock hood....air gap, 3 inch cleaner?
