I was going to weld up some trim holes on the rocker panels of the cuda. My plan was to use some common nails and weld the heads into the holes and then cut off the nail. Never got around to trying it though.
The problem with that is the effort and time to clean the nails before welding on them.I was going to weld up some trim holes on the rocker panels of the cuda. My plan was to use some common nails and weld the heads into the holes and then cut off the nail. Never got around to trying it though.
Not everybody. Glad you could prove them wrong. Flux core works pretty good when that's all you have!Yea it is a unique sound and welding experience before this i had only ever welded with an arc welder. I'm learning tho. Eventually when I have a garage and some 220 power I will upgrade to a mig. I also want to learn tig welding. I really enjoy fabricating I want to get good at it. I have will power and work ethic that I can pretty much accomplish anything that I set my mind to eventually. Everyone said you couldn't weld body panels with a flux core so far I have done cab corners in my buddy's truck, floor pans and trunk pans. Where there's a will there's a way!
Yea I am it's coming along working on it again today I have to run some errands this afternoon I will get back at it some more later todayLook's like your making good progress on the Dart!
Yea I have had alot of support from you guys in this site. I have learned alot. My biggest struggle starting out was my power supply. The outlet I was using was over used. So it was just lagging so much I switched and went to an circut that only has 3 outlets on it and noone ever uses those three and it's a 20amp circuit. That helped tremendously. I still have to run and extension cord for now so I am limited to what I can weld for now. I am gonna run a new wire from that outlet to outside and make another outdoor outlet I can plug straight into with no extension cord and I will be set then. I got me some wire to do it I just gotta do it. I have been so busy havent had a chanceNot everybody. Glad you could prove them wrong. Flux core works pretty good when that's all you have!
Also, find a block of solid copper, use it to back up holes you are filling in.copper wont stick. And a steel tig rod helps to fill bigger gaps.I'm finding better results leaving a wider gap between the two pieces you are welding together and the wider gap allows you get the weld hotter and stay on it a bit longer and get a better penetrated weld. Then when you grind it you have more weld to grind, which is good.
The little rectangle on my firewall, i fitted the piece as a perfect fit with minimal gap and then I couldn't stay on it at all and when I grinded it down I didn't like the shallow weld so i am going back and making a gap with a cut off wheel and going over it again.
Did it have a/c ? Or are you trying to go gas pedal and wiring harness delete?
I made a magnetic holder for mine.Or carbon. Problem is you can't get behind every hole. Some trim holes in 1/4 panels are almost impossible to reach from the inside.
Even when it is accessible like in the trunk, you would need really long arms or a helper.
Or just wire bridge it from the front
I got a friend who's made his living welding. Notorious for not wearing a helmet."30 years experience" I don't care if it's 60 years, he's a fool for not wearing some kind of welding helmet.
His neck always had a flash burn and he'd get arc eye a couple times a year.
He got cancer in his neck. Damn near killed him and he had to relearn to eat and swallow.
I was at his shop the other day, he's welding something, no helmet. I got on him about it and of course, the cancer wasn't caused by the UV light, it was something else. blah,blah,blah....
You can't tell him, he won't listen.
Any pics?49 model. No AC. It had a heater though. And no, I am filling all of the holes and starting from scratch so that only the needed holes will be there. There's a pile of um right now. I do have a small aftermarket AC and heater to go in it. But of course, that will not utilize any production holes.
That just makes no sense at all. I know the old non darkening helmets were a little bit of a pain, but now we have these badass auto darkening jobbies that there's zero excuse not to wear.
I guess it's what you get used to? I bought my old Jackson hood when I was an apprentice, non auto. I did add a neck flap to keep the welding boogers from going down my collar. I used an auto hood that the compnee bought for me sparingly. Always grabbed the the my old one first. The auto was handy at times with the big innershield Mig when I knew it would be an all day project. Even then with the hood down I found myself doing the head bob thing to get the filter in place
But you at least USE ONE.
gas door is going to open driving down the road.
Most nails are coated with a galvanized or blue oxide finish. All of that needs to go before welding because a good weld would not happen with those coatings in the way and welding on galvanized can produce a poison gas.
Maybe sand blasting the nails would help but it would be faster to weld fill small holes with the welder. I ran into that on the side trim holes on a 68 dart.
Here is another nice tip from the same guy
The kicker is, he has 4 or 5 of those type helmets lying around. He's got one hanging on every welder in his shop. Probably a dozen or so of the old type on shelves. I don't get why he doesn't use them. His dad is/was the same way, though.That just makes no sense at all. I know the old non darkening helmets were a little bit of a pain, but now we have these badass auto darkening jobbies that there's zero excuse not to wear.
