Use whatever cam you want. There's so many recommendations here and some may be right and some not what you want. You know what they say about cam choices, They are like buttholes, everyone has one.clened up nicely
Back in the day when I would get done honing a block, I would always wiped down the bores with a lint free thinner soaked cloth ( cloth baby diapers were perfect). Doing this removed any fine metal shavings from the cross hatch pattern.
It sure is, I couldn't believe how much dirt and grime would be on those cloths, if I remember correctly I used 3 cloths per bore. The main thing is to use lint free towels, rags etc, if not those fine particles will stay in the bores. I don't think it's possible to be to clean upon assembly.we washed it with soap and water then wiped with wd40 and clean rags until they came out clean.. amazing how much dirt stays in there. it will get wiped down again before assembly.
I've never tried this, but a friend of mine uses dawn dish soap ( liquid ) in his power washer he claimed it gets everything super clean
I was leaning towards the Oregon, but just remembered you're using the low gear set so i would go with the MP myself as i believe it would give a little more mid range torque. Just throwing out another opinion.
I believe that you did a excellent job of cleaning up the block, I'm sure that you will get good results from your combination.we washed it with dawnand rags and still had a ton of stuff come off the rag afterwards. maybe the pressure washer helps but i'd still clean each bore out afterwards..
Did you gap the rings?rings fit, bolt holes all chased. gotta quit early today, daughters first lacrosse game of the year. she wants me to take pics. not off again until monday so we will pickup then.
Awesome, I think that you'll have a great running car.
That MP cam will do nicely... IMHO run it!.oh man.. yet another cam dilemma. the oregon cam is still a coupe weeks away from even getting shipped. my buddy dave found a mp cam and lifters in his stash (new in the box). he thinks it would be perfect in the motor.. my other budy tom thinks it may be too big and thinks the oregon cam would be better... if i use the mp cam the motor will probably be together and probably running on a run stand next week.. with the oregon cam its still a couple weeks out... i trust both guys very much but not sure what to do with this damn cam now..lol if cam science wasn't so voodoo to me it may be an easier decision..
this is the MP cam: Mopar Performance P4452759AE Mopar Performance Purple Camshaft Kits | Summit Racing
this is the oregon cam:
#1522
204/214 @ .050”, 270/280 adv, .420”/.443” lift, 112 sep
The MP cam is close to a 340 cam run itprobably am over thinking it.. i like keeping it simple but i've had way too many oprions with the damn cam..lol
I’ve always heard and thought of that particular cam as the upgraded 340 cam since it holds close to the stock valve lift but just has increased duration and by good bit. Lift is the only close area that the cam is in. The LSA is a 114 vs 110 and the duration picks up for an extra 13*’s @.050.The MP cam is close to a 340 cam run it
I needed a new motor and got a 340 from a wrecked car with low miles. Stuck one in, all power stuff on it. Power brakes, steering, A/C auto with stock 340 Dayco converter, in 727 with 323 gears ran very well.I’ve always heard and thought of that particular cam as the upgraded 340 cam since it holds close to the stock valve lift but just has increased duration and by good bit. Lift is the only close area that the cam is in. The LSA is a 114 vs 110 and the duration picks up for an extra 13*’s @.050.
IMO, it’s a very good cam from the factory.
I clicked on the link for the MP cam and it said not available, I checked another place and it said the same thing. Is this cam no longer available?
