Viscous fan package?
Heating / Cooling / AC
  1. famous bob
    famous bob mopar misfit FABO Gold Member
    16,606
    6384
    Aug 14, 2011
    okla
    Local Time:
    12:37 PM
    I still don think they will cool as well as a 6 or 7 blade fan, they were made to keep fan noise down.
  2. famous bob
    16,606
    6384
    Aug 14, 2011
    okla
    Local Time:
    12:37 PM
    AGREE ON THAT ABOUT THE OLD GUYS, BUT , THIS OLD GUY HAS ABOUT 8-10 DEGREES HOTTER RUNNING ENGINES W/ A CLUTCH FAN . d r caps
  3. abodyjoe
    abodyjoe Well-Known Member
    20,659
    5803
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    1:37 PM
    this the fan?
    MOPAR 5 BLADE 18" RADIATOR FAN 4140063 NOS | eBay
    • Like Like x 1
    • halifaxhops
      halifaxhops It's going to get stupid around here! FABO Gold Member
      59,223
      27496
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      1:37 PM
    • 67dartgtgo
      67dartgtgo FABO Gold Member FABO Gold Member
      1,088
      489
      Nov 9, 2012
      Mass
      Local Time:
      12:37 PM
      Those are them.
    • Jimacuda
      Jimacuda Well-Known Member
      1,759
      563
      Nov 10, 2006
      Phoenix AZ
      Local Time:
      10:37 AM
      Factory flex fan Bob or aftermarket?
    • Jimacuda
      1,759
      563
      Nov 10, 2006
      Phoenix AZ
      Local Time:
      10:37 AM
      Excellent. :thumbsup:
      I've had a couple of those hanging around for years. :D 20200601_101234.jpg
    • 67dartgtgo
      1,088
      489
      Nov 9, 2012
      Mass
      Local Time:
      12:37 PM
      Geesh....I guess you have...lol
    • Mike69cuda
      Mike69cuda 64 is the new 17 FABO Gold Member
      1,485
      1106
      Jan 2, 2018
      Overland Park Kansas
      Local Time:
      12:37 PM
      I guess you are prepared for the zombie fan apocalypse. But at least you save something useful, not so much in my garage....
    • Jimacuda
      1,759
      563
      Nov 10, 2006
      Phoenix AZ
      Local Time:
      10:37 AM
      only if theyre viscous zombies:D
      flex zombies are down another aisle:steering:
      if you could zoom out in that picture youd see lots of "WTF am I saving this for?" toe stubbing, leg gouging masses of "crap, ive got to move that again"....ugh.:)
      Lets not even go out behind the shop...no no...:eek:
    • Mike69cuda
      1,485
      1106
      Jan 2, 2018
      Local Time:
      12:37 PM
      Bob, I am trying to put all the bolts in my Hayden 2947 fan clutch. It is more difficult than I even imagined. I had one bolt in for mock up before. I am trying your stud method now & that is even hard. Any other tips?
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      60,809
      32468
      Jun 7, 2010
      Georgia
      Local Time:
      1:37 PM
      • Like Like x 1
      • mopowers
        mopowers Well-Known Member
        4,718
        1824
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        10:37 AM
        I use bolts on mine. It helps to just get the bolts started first - like a thread or two on each. That'll allow you to pull the clutch out in order to fish them all in. Then use an open end wrench and snug them all down one flat a time. It's a shitty process, but it can be done.
      • beanhead
        beanhead Well-Known Member
        115
        145
        May 21, 2017
        wackyfornia
        Local Time:
        10:37 AM
        Yep. It's been described as "a real pain in the dick!" Pretty much sums it up.
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • beanhead
          115
          145
          May 21, 2017
          wackyfornia
          Local Time:
          10:37 AM
          Interesting...When my 5-blade was destroyed by a General Lee-style crossing of some train tracks, I switched to a factory 7-blade and it pulls with noticeably more suction, at least just spinning at idle.
          • Like Like x 1
          • famous bob
            16,606
            6384
            Aug 14, 2011
            okla
            Local Time:
            12:37 PM
            I didnt use studs this time , I used a hair longer grade 8 bolt w/ a flat washer .
            I cut the lip off of the back of my clutch ,about .100 , wish I`d have gone another .20 or .030, that lip doesnt do anything , and is just extra mat`rl.
            I still had to install one bolt ,"leave ''unscrewed'' a bunch, to set the clutch groove in , to help get the fan in position, and rotated it around ,starting all the bolts w/ it way loose , and had to use needle nose pliers to get it in position ,( I WAS DOING IT W/ BURNED FINGERS ON MY RIGHT HAND). If u tighten one to far, u cant cock the thing out enough to get all of them started. w/o cutting the lip off , I doubt I could have done this ,then it would be back to using the studs , u can cut carburator studs to the exact length < trial and error .
            Cutting the back of the clutch can be done easy in a lathe , my lathe took quite a bit of imagination because it wasnt big enought to swing the clutch over the cross slide , I would recommend having it cut by a machinist , would be ''no big deal.''
            HANG IN THERE , ITS STILL A BITCH !----LOL
            • famous bob
              16,606
              6384
              Aug 14, 2011
              okla
              Local Time:
              12:37 PM
              Beat me to it -------
            • famous bob
              16,606
              6384
              Aug 14, 2011
              okla
              Local Time:
              12:37 PM
              Well it seems the smaller pulley made about 5 degrees diff. , not sure, it was only in the mid 80`s but was humid as hell . Stiill wondering how much it will help in the mid to hi 90`s .
              • Like Like x 1
              • Mike69cuda
                1,485
                1106
                Jan 2, 2018
                Local Time:
                12:37 PM
                Bob, I got it in, what an ordeal. I cut off some bolts like u suggested and used red locktite to hold them in the waterpump. I took the bolts out of the fan so it would tilt out of the way a little & give me a little more room. That made it a lot easier. I couldn’t get a lock washer on it, so I hope it it will stay tight. Looks like the slots in the clutch might dig in to the nuts and help.
                I have a 7 blade fan. Looks like it would be easier with a 5 blade fan since they are asymmetrical and there are bigger spaces between some of the blades.
                Having a bag of nuts helped cut down on the swear words, since I didn’t have to get under the car every time to look for a nut. I bet I dropped 30 or 40 of them.
                I made a shroud out of a Ford Explorer shroud, and it is two piece, so I can install it last. That was very helpful as well. Don’t need anything else in the way to make it harder.
                Machining of that ridge is a great idea, but out of my skill range. I wonder if Hayden ever actually installed one of these?
                Thanks again for the help!
                • Like Like x 1
                • 67dartgtgo
                  1,088
                  489
                  Nov 9, 2012
                  Mass
                  Local Time:
                  12:37 PM
                  Fantastic member fshd4it hooked me up with a 5 blade brand new in the box kit. Threw it on yesterday and tested it out for a few hours. That baby really moves some air. It’s hugely noticeable even at slow idle compared to the piece of crap flex fan that was on it. Constant cruising temp 182*, stop and go traffic drifts to 196* on an 86* day. No shroud yet but definitely considering it.
                  74A3FB51-E9BA-4C58-AF5C-6224BC50765F.jpeg BF7D0CCE-9AE7-4697-807D-602CEB90BFEA.jpeg
                  • Like Like x 1
                  • yellow rose
                    yellow rose Doctor of Thinkology.
                    22,075
                    18149
                    Jun 19, 2015
                    Living on the razors edge
                    Local Time:
                    10:37 AM
                    That’s close enough you don’t need a shroud.
                    • famous bob
                      16,606
                      6384
                      Aug 14, 2011
                      okla
                      Local Time:
                      12:37 PM
                      2 dif. aftermarkets , never seen a factory flex !!
                    • famous bob
                      16,606
                      6384
                      Aug 14, 2011
                      okla
                      Local Time:
                      12:37 PM
                      notice its a small block !
                    • famous bob
                      16,606
                      6384
                      Aug 14, 2011
                      okla
                      Local Time:
                      12:37 PM
                      Dont know , I doubt it , got any pics of ur set up ?
                      I ran the nuts only ,till this last change , had no problem w/ it/them.
                    • Jimacuda
                      1,759
                      563
                      Nov 10, 2006
                      Phoenix AZ
                      Local Time:
                      10:37 AM
                      Now you have.
                      • Like Like x 1
