darepairman
Hey fellas, I have a 72 Dart with a 318, I installed a kit from Summit with a Mallory 6A ignition box, comp SS 32 series distributer and Mallory coil. I removed the old ignition box and ballast resister and used the wire from the regulator to the old resistor for the switched power supply, when I fired it up it started up and ran and then the RPM went way up so I turned it off, come to find out the 6A fried, exchanged it for a new one. but before I hook it up I am making some checks, Bought a new regulator, now checking the voltage on the switched wire I put it on a charger and I read 16 volts when on a charger after the regulator, My question is, is this normal to read high voltage after the regulator? I dont know if this fried the 1st unit cause I was using the charger to start it.
Thanks Ed
Thanks Ed
