Why wouldn't it? They clear on mine perfect and mine has less wheel well room than yours.Many thanks to everyone so far!
I did check tires-easy, same issue is that they had a big selection in that size, but every one was a trailer tire.
The one at discount that Dana67Dart posted was a trailer tire, but the one at Summit might do it! I'll look into that one a bit closer as that would save me from having to switch.
I'll look into that also and check to make sure that the additional width will clear when I turn. It's tight in those wheel wells.
Thanks a ton for the help!
