Water Pump Adapter, Need help soon.
vestracing
Member
Ankeny, IA
All, have an odd part that came on our car when we bought it and now it is failing.
It is a water pump adapter that has two block adapter and an anodized tube that runs between them. That tube has an adapter for the upper radiator hose. It adapts a chevy water pump to the block with the normal outlet on the water pump going to the lower radiator hose.
First Question: What is this (a reverse flow water pump manifold?) and who made it? If anyone has any ideas it would be a huge help.
Second: The tube running between the two block adapters is leaking coolant and I would prefer to not to have to give CSR or Mezeire $500 for a new pump.
Called CSR (Formerly CSI), it is one of there pumps from pre-1998. Looks like I get to buy a new water pump before this weekend. Anyone have any thoughts on Meziere, CSR, or CVR for the big blocks?
I like Meziere. Have two of their pumps on both my small blocks. Good customer service.
When I ran big block I ran a ShoGun water pump that was great..... but they're no longer in business. Pump mounted to the inner fender and there was only a small aluminum water manifold that attached to the front of the motor plate. Sure freed up alot of room on the front of the engine.
