Zrksi
New Member
Having problems with the water pump pulley coming in contact with the crank pulley. Is there a difference between 225 and 170 water pumps? I may ordered a 225 water pump for my 170 but it fits perfect I assume
Welcome to the site, by the way. Toss an intro and some pictures of your project over in the Welcome Wagon.Having problems with the water pump pulley coming in contact with the crank pulley. Is there a difference between 225 and 170 water pumps? I may ordered a 225 water pump for my 170 but it fits perfect I assume
did they do the A/C-non A/C fin count change? Ive seen so many rigged Mopar pulleys with spacers you'd think it was stock.No, with one exception: In 1960 (only), the 170 engine used a 3-1/4" diameter impeller. All other Slant-6 water pumps have a 3-1/2" impeller. There are no differences in hub placement or other dimensions.
Please show us pics of the interference you're getting; it sounds like you might be trying to use an incorrect water pump pulley—probably not from a Slant-6; AFAIR the only differences in Slant-6 water pump pulleys are single- or double-groove; same diameter either way.
